I have a 78 dana 44 hd out of an f250. It has 4.10 gears. The axle in my truck is a 78 dana 44 from an f150. I am doing an 8 lug conversion and my new sterling has 4.10 gears. The gears in the dana 44 f150 axle are 3.50. Are the gears/carier/ etc the same between the two. Also what master overhaul kits to you guys recommend. I need all new wheel bearings, axle seals etc..
Some assembly required!
Yes, the gears and carrier are the same between those two axles. As for install kits, I generally get Yukon, and they're sufficient to do the job, but I really can't say if another brand is better or worse.
The kits aren't really Yukon. They are either timken or koyo bearings sold by randy's under the yukon name. The kit is like 109.00 from me.
