1 - 20 of 21 Posts
1978 What bushing is this? I've looked up all kinds of parts diagrams and I guess I just don't know what I'm looking at. :whiteflag The bushings on both sides are completely gone. Thanks for taking the time to help
Looks like your stabilizer bar(sway bar) link, but I don't see your stabilizer bar.
Is that piece in the pic just hanging there?
Steering stabilizer bushing, however your steering stabilizer is gone as well.
Oops, I see the stabilizer bar is there.
Thanks a lot. Yeah I think everything is gone lol. Looks like the play in the steering starts right there at the Steering stabilizer bushing. I've got a lot of work to do looks like.
First picture clearly shows the anti sway bar, underneath the axle, secured by a "U" bolt. It also shows the sway bar link bushings are shot!!
Thanks for the quick responses, I guess my front end rebuild has officially begun. Well almost, I've got to take it to the lake this evening. Everything is toast under there, I'm a motorcycle guy I've never done a front end before so I've got some reading to do. Thanks again this forum will be invaluable to me.
One reason I couldn't find the bushings is the new ones look completely deferent than the originals.
Lots of sunlight
Old top link bushings
Neither of those pictures shows the steering stabilizer.
Considering it is in front of the cross member I have no idea how you could see if it is there or not to come to the conclusion he doesn't have one.
Saint mucus post a picture of the front of your axle.
Alright, this is good if I know what to buy I'm confident I can replace the worn parts so thanks for all the input.
Here's a few pics from the front. I can take more if needed.
Front
Passenger side
Drivers side
Just from the pics;
tie rod ends look pretty new
steering stabilizer bushings are close to, if not toast
Pull your stabilizer loose, at the rod end and see how much resistence there is, pushing in and pulling out. If it goes in easily, then time to replace. Typically, the stabilizer will come with new bushings, just like shocks do.
Actually the first pic does show the stabilizer, I just did not notice it :banghead
Discussion Starter #14
Okay I've since replaced the drag bar and steering stabilizer and now I have a new "what's this" question. Here's a pic, I can move it around by hand easily so I guess its next. Looks like I'm going to be redoing this entire front end so which serves manual do you guys suggest?
That is called the track bar. Check the bolt that mounts to the axle, sometimes they get worn out and cause play. Best replacement for that is an Ingalls tapered bolt.
Discussion Starter #16
Thanks. Looks like it's going to cost a little more than the $15 bucks for a bushing kit. I haven't even broke the nut loose and I can wiggle the bolt around by hand. Guess I need to read up on that tapered bolt.
Discussion Starter #18
Yeah man after you told me what I was looking at and I got to reading about it the bolt hole is definitely worn. I'll be ordering the bolt you linked to and as for the reamer it looks like the forum favorite is the KD #2044 so I'll be looking for one of those too. Thanks again
EDIT: Well looks like the KD reamer is no more, hopefully I can barrow one from work if not the tool is going to cost more than the bolt and bushings together lol figures.
Discussion Starter #20
Okay I've got the Ingalls bolt ordered now for the reamer. The cheapest one I've found is from Speedway motors http://www.speedwaymotors.com/Speedway-Tapered-Ball-Joint-Reamer-10-Degree,29005.html only problem is in one of the Q&A's this was asked
Question
"Is this reamer 10° or is it 9.56°. 2 inch taper per foot should be 9.56."
Answer
"This reamer has a 2" per foot taper. It is not a true 10 degree taper like you have referenced."
Will a 9.56 tapered reamer still work with the Ingalls bolt? I haven't ordered the reamer yet but as soon as I know it'll work I will.
1 - 20 of 21 Posts
