Anyone ever put a 79 Bronco body on 79 F-250 frame?. Aside from shortening the f-250 frame is it difficult? Thanks
that is just ridiculous. all you would gain for that insane amount of effort would be slightly better front brakes, and a more expensive rearend that isn't any stronger than the 9 inch. what is the reasoning for this possible frame swap?
Better axles that already have the lower gears in them. More of a cost saver thought than anything.
May seem ridiculous to you but I'm sure stranger things have been done!
swap the axles, not the whole frame. if you went with leaf springs it wouldn't be so difficult.
Swap the axles.. You'll be a lot happier you did..
I've swapped axles and I'm in the middle of a body swap.. Axles is a lot easier
