1 - 3 of 3 Posts
Looking for a set of Diff covers that have a drain and fill plug...I dont offroad so Im hoping for something not as expensive as the bullet proof ones.
I have a 44 front and 9 inch rear.
Local # 40 Boilermakers
So you really only need one for the front. If your wanting one with a drain plug the beefier covers is what comes to mind. If you can fab I would cut one out of a ttb front 44 and weld in a drain plug. IMO a drain plug is kind of pointless though, especially on a straight axle.
will have to drill and weld a bung on the 9'' rear
on the front, it is easy to just pop off the cover and drain fluid if you need to change it ,clean surfaces,then bead a silicone assemble
it may be helpful if you are planning on taking it swimming all the time,
1 - 3 of 3 Posts
