negative creep
will a detroit from a 94 8.8" with the vss work in an 89 8.8" without the VSS. never taken either one apart and looked at the differences. i don't know where the VSS mounts so i don't know if i it would be an issue. i am guessing no, but what do the experts have to say?
In The Matrix
Good question, I think.
I know they sell them for 8.8 31 spline with ABS, and a seperate one with different part numbers without ABS. If you have ABS, and I am sure he does, I would say yes it fits.
That could be way off tough.
A little searching reveals
Differentials - Detroit Locker Applications
187C-146A FORD 8.8" 1986 & EARLIER 4.56- 31
187C-145A FORD 8.8" 1987 & LATER 4.56- 31
ate lug
88 + 96 broncos, 96 F250
It seems to me that it would work.
The VSS is on the axle shaft, not in the diff., so i cant see that being a problem. The RABS sensor's tone-ring is on the ring gear, so as long as you can still put the tone ring on, i see no reason why it wouldnt work.
Anyone else?
edit:
beat me to it. :doh: Yeah, with that info, id say itll work! :D
