Anyone want to convert to a solid axle? Might as well go 8 lug while you are at it.
I have a solid axle D44 front with flat top kuckles and 4.10 gears. It's drivers side drop and high pinion. It's complete from hub to hub and even has the lug nuts with it. The brakes even look good, but there is rust on the rotors. I also have a D60 rear that has 4.88 gears. Both axles are stock and I need $600 for the pair.
423-737-0265 -- Shawn
