So I building my F250 up and i need a 8" rear spring. The only 8" rear spring for a ford i found was for a bronco, but was $600. The 6" rear spring for the F250 is $302(pro comp). Im sure theres a way of not needing to run a block in there. I HATE BLOCKS! Im just not 100% sure of how to do it:banghead. Will it work if i get the 6" springs and use a long leaf aal, or am i also going to need a short leaf aal. I already am running a reverse shackle kit, im working on 13" of lift or so. so 8 or 9" springs will be perfect. thanks for any help guys.
aka: kemicalburns
there are various spring companys, might contact them about building springs specific for your needs. national is a brand that comes to mind.
get a longer shackle. Like plug says, leaf springs REALLY suck when you start arching them. They dont flex for crap and they are pretty unstable to ride on.
You wouldnt by any chance know where i can get a longer shackle woud ya?
thanks again guys
Master Bater
belltech makes a 150 2wd lowering shackle that is 7.5" long. It needs spacers at the hanger, and widening by 1/4" at the springeye, but many of us have been using them for years. a search should turn up lots of info, or there are some pics on my sf.
