Like it sounds. Starting plans to build my 80 (originally just parts truck) bronco into a road racer deal loosely based on lightning. Lot of reasons lol. Anyone have any good ideas or want to try to talk me out of it? I'm using a 302 instead of a 351 bc it's what I have on hand. Also 5spd. And the truck has a ten inch lift right now so I need to source the suspension and whatnot.
Yo Jawwill8089,
WELCOME! & I doubt that no one will try to yak you out of a road racer configuration!
But that 10 inch lift?
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention. I'll move this thread to Noobie section because Build section usually requires 30 no padded posts to enter or later, add more remarks.
When you get to 30 posts, send me a message and I'll move back here.
How To Find Conversations (Private Messages) »
From the navigation, near the upper right-hand corner, click on your avatar to open the drop-down menu and select “conversations”.
To save you time and for better responses, please fill out your Signature with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
Our Forum faqs @ https://www.fullsizebronco.com/help/faq/
Includes for example:
How To Upload Images To Posts & How to Use Search
See more tips!
Baba-looeys Favorite FSB Links, Lots of Tech Links @ https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/131287-baba-looeys-favorite-fsb-links-lots-lots-tech-links.html
Here is the 1980 Bronco Dealer Brochure via Josh B
1980 Bronco Advertisement
1980-1986 Bronco/F Series Fasteners by Gary
1980-1986 Bronco/F Series Carburetors, Chokes & EFI by Gary
1980-1986 Bronco/F Series Specifications by Gary @ Axle Ratios - Gary's Garagemahal (the Bullnose bible)
Differences in 1980-1986 Bronco/F Series by Gary
1980 Ford Truck Service Chassis Highlights by Gary (similar as Bronco) http://www.garysgaragemahal.com/1980-truck-service-highlights---chassis.html
Includes the proper adjustment of the parking brake tensioner & rebuilding instructions on the Dana 60 axle and the NP208 and BW1345 transfer cases.
1980 Ford Truck Electrical Chassis Highlights by Gary (similar as Bronco) @ http://www.garysgaragemahal.com/1980-truck-service-highlights---electrical.html
Explains electrical features of the Bullnose trucks, including the exterior lighting, digital clock use, speed control installation & testing, CB radio installation & controls, ignition switch removal & installation & logic test, fuse panel, etc.
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @ https://web.archive.org/web/20130419152159/http://www.broncocity.com/66-81manual.htm
1980 Free Wheelin' Fords Brochure, including the F-Series, Broncos, E-Series, and the Courier by Gary @ http://www.garysgaragemahal.com/1980-free-wheelin-fords.html
announcing the 1980 Free Wheelin'...
Free registration for Technical Service Bulletins, (80 through 96) same as by Ford; Search Wiring Diagrams
Try to find time to participate and VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
Full-Size of the Month (F.O.T.M.) contests will be held in JANUARY, MARCH, MAY, JULY & SEPTEMBER. Each month in-between will be used for nominating contestants to run in the following Month.
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Vote for the ongoing Full-Size of the Year (F.O.T.Y.)!
Al
Ford Hoarder
78 & 92
The lightning trucks uses a 4x frame as due to the extra stiffness it provided.
How in depth are you wanting to go??? Some will say an 80 may not be great starting point due to the way Ford made the frame that particular year, they added several holes in an effort of weight reduction. A few years (im not forsure exact date) they would make the frames more solid.
Not that you cannot build it with what you have, just something to keep in mind.
Personally if I was building a 2wd lightning Bronco, that needed a 10" lift removed. I would go the route of a double a-arm and coil sprung front cross member, or possibly swap in a crown vic front end as many f100 owners have done.
Could also get 2wd front end parts and swap it over, or run empty stock 4wd arms. The knuckle and hub is stronger.
Im not one to talk you out of it, I have been giving some thought to doing the same with one of my own.
Eric
It's a neat concept. I just don't know how it would look being lowered for handling. The BKO has kind of a "tall" body appearance. It's not that long of a wheelbase, so its height is emphasized when viewed by the eye. Lowering a BKO might make it look kinda like an oversized VW Bug. However, as the saying goes: Your car. Your money. Your choice.
1996 Bronco XLT, 351W / ZF5 (under construction) 1996 F150 XLT, 351W/E4OD, D44 SAS
Since you’re doing it 2WD, will you be using a mustang 5spd instead of the Mazda truck one? I figure that would be better for faster, sportier shifts.
If you want to go way out there, my friend from college that introduced me to junkyarding always said he’d like to see a tbird IRS under a lightning.
