1 - 9 of 9 Posts
recently my starter broke so today i replaced it, it sounds great but i also replaced the distributor cap and the rotor and i also replaced all the spark plugs. i did some other tune up stuff but that is all that dealt with the ignition process.
it basically just sounds like it is not firing, any help at all would be so appreciated. i will load my profile and stuff tomorrow.
ps it doesnt sound like a big deal i rechecked all the wiring from cap to plugs it is all in the correct order any way just any tips please i need it to start running again.
trying to go fast!!
dang that sounds like when i got my dis cap wet i hope it works out iam have some problems with my bronco right now to
is the starter engaging, or is it just dead?
also have you checked for spark?
I'm not sure what its called, but check both pieces of the cap. I'm not sure if the 80 has the two-piece cap setup. Mine does and the piece that is below what most people would call the cap can get loose.
Any chance you knocked it way out of time whiel messing with the distributor?
X
Guest
Any chance you fowled up the firing order? I did that once. Plus make sure all you connectors are secure and in place.:toothless
1 - 9 of 9 Posts
