302 carb. C6...Dark Blue.. Blue int. Rear window has new gear kit installed...passenger window motor bad.. driver door lock is stuck in the unlocked position..... inside uphosltry almost perfect...wipers do not work.. bad wiper motor.. replaced switch and relay...All gauges work...center console has crack in top...leaking oil somewhere.. not sure yet..not valve covers.. not rear main... possible front cranshaft seal or possibly oil sending unit leaking...tranny shifts great..transfer case is great...manual hubs..has ac components but fan for heater/ac is not working...removed motor ran a hot wire.. blower motor is good... blower switch bad... Just replaced both front calipers and pads.... brand new power steering pump and belts.... has 32" bf mud terrains.. close to worn out...has rear tire carrier with 31" goodyear AT....recent smog test... very little rust... 1300$ Douglasville,Ga
