84 6cyl, new carb just passed smog, TFI ignition -
Good spark good coil and full tune up
RUNS GREAT on sunny days
CLOUDY OR RAINY barely starts and when it does we have 80% power loss under load..
Why would it run good on sunny days and bad on cloudy/rainy Days???????
Please help me!!!
Its there a dense air sensor or something like a Mass air flow sensor (doesnt have)!!?!?!?
Help me!
AMBER-
Runs BAD when Rains or Cloudy days!!
Steve83 said:
Does it have a feedback carb?
From the diargram u have posted it appears that i DO have a feed back carb.
the digram posted is LESS complicated than the one i have bolted on.
Its a holly carb single barrel and brand new re-build -
Is there a SENSOR or something that can read MOISTURE and/or DENSE AIR?
Runs GREAT when SUNNY and CLEAR OUT
VERY POOR when CLOUDY AND RAINY!! Hard start and 80% power loss!!
HELP!!!
Thanks for all your replys!! ANYONE HAVE AN IDEA???????:cry
will post results
thanks steve, gonna go and pick out 3 or 4 map sensors from pick and pull tommrow and see what happens. 2.00$ for 3 possibly good map sensors anit a bad deal. but yeah last step i will do is get a code reader and go from threre
new o2 senors so must be map yeah????
Sorry for the double post steve!
map sensor - - - -
Yeah i hear ya - i was told that any map sensor will work as long as its is PRE 1990's and below even if its just a full size ford truck - is this true?
does it matter if i have a inline 6cyl and pull a map off of a v8??
for 2 bucks at pick and pull ill try it be for i spend 106 bucks on a brand new after market yeah???
84 bronco 4.9l inline 6cyl
If its NOT the map sensor any other ideas??
Thank you VERY much for your help steve!!
Re check your secondary ignition, bad cap? Spray things down with a water and alcohol mix to make the problem happen when you are working on it.
