Buy Haynes and search, orpsygn0sis said:How do I adjust the timing on my TFI dist. ? The book does not say how.
Do I need to disconect anything to set the BASE timing ?
Didn't know that either. Maybe someone can set us straight as to whether it should be shut off first or if it should be pulled while runningBronco4Life said:Oh, didn't know you could unplug the SPOUT with the truck running, thought it only made a difference when the truck was restarted. Wish I had known that today lol, checked my timing just to make sure it was at 13-14. Woulda saved a start up lol.
I hooked up the timing light with the spout still in just to see how far it was advanced at idle by the computer, and as i was watching it, it was actively changing it, was anywhere in the 10-20 area everytime the light flashed. I figured it would just make small changes to the timing, never thought that it would be actively manipulating it like that... not that it really matters, I just thought it was cool.
yeah mine fluxuates also.... a good 10 degs..Bronco4Life said:Oh, didn't know you could unplug the SPOUT with the truck running, thought it only made a difference when the truck was restarted. Wish I had known that today lol, checked my timing just to make sure it was at 13-14. Woulda saved a start up lol.
I guess you didn't look at the photo posted by sixlitre, it's completely obvious that the SPOUT connector is not on the fender in that photo. I believe it was 92 when the TFI module was moved off the distributor.Bronco4Life said:Er?
My spout connector is on the TFI module over in the driver side corner, no where near the engine.
They put the spout connectors on the distributors?
That sneaky [email protected]$turd SixlitreRick3373 said:I guess you didn't look at the photo posted by sixlitre, it's completely obvious that the SPOUT connector is not on the fender in that photo. I believe it was 92 when the TFI module was moved off the distributor.
