1 - 4 of 4 Posts
I play with my
I'm about to hit 85k miles on my 96 351 bronco was woundering if there is any special things I should do with a tune- upif so please respond thanks~Kyle
green ones make me horny
When is the last time you got the tans flushedf, diffs changed out, coolant flushed, and all that good stuff. i would just go that route and clean the engine real good.
ken
Yeah, I would defintely check on getting the 'transmission' fluid drained and flushed. Some shops will do it right, getting ALL of the old fluid out, and change the filter for about $100. IF you wait too long (after 100K mi) it often does more harm than good to do this flush. Look for a shop that knows 4WD's or the E4OD and ask them. If you've never had this done it may already be too late, and just want to change the filter.
30K miles is a good figure on the drivetrain fluids, so you are prolly overdue on the axles and t-case if they never had service. Check for metal filings and water in the old fluid, or usually low level/lack of. Think about switching to a synthetic like Royal Purple for your axles, type depending on if you have L/S or not. The t-case uses AT fluid, don't put oil in it!!!
As for the engine, check or have the shop check for any oil leaks, like from the rear main seal or oil pan gasket. It's not uncommon for the oil pan to rust out in the winter climates. Check timing, do the tune-up, test the fuel pressure, test for engine/tranny codes, and inspect the spark plugs yourself, especially the no.8 cylinder.
I am also about to hit 85,000 miles. I tuned-up at 60,000. It was definately too early for the spark plugs; they were in good shape. But I should have changed the distributor cap much sooner. I will change it again at 90,000. The wires are still good and have been put to the test: I had to drive in Hurricane Rita. Truck didn't miss a beat with driving rain coming straight into the grill
All my driving is on rural interstate or off-road. At 60,000 I replaced the factory front brakes as they were worn, but still had some mileage left. (I didn't want to do the wheel repack thing again in 15,000 miles). I re-checked the rear brakes at 83,000 and they are still going strong.
If your truck was used, now is a good time to investigate what maintenance may not have been performed. People frequently neglect coolant changes and front bearing repacks.
You may also want to convert to synthetic lubricants. I installed synthetic tranny and rear end fluid in my Bronco at 30,000 miles. You can feel the increase in smoothness.
In some cases, it does not pay to wait to do maintenance until it is due. If you plan to keep your Bronco until 150,000 miles, you will not save anything by waiting until say, 100,000 miles to change the rear end oil. By changing now, you get all the benefits at no increase in expense. And you will never have to change it again.
Red
1 - 4 of 4 Posts
