I have a 86 Bronco with a 302,
I will start and run all day if you want it too. If however you turn it off it will not restart for a few hours. I have already replaced the following:
Distributor Cap
Distributor
Plugs
Wires
Button
Voltage Regulator (for the hell of it)
And Yes I replaced the module on the distributor and no there isn’t one on my firewall.
I can smell fuel when I try to restart
I can hear the fuel pump running the first time I turn the key on (priming)
This is the best I can do I work on guns not trucks but I got a great deal on this thing. Also my rear window doesn’t work I don’t hear anything trying to run back there.
68 an hour is too cheap, i'm charging $85.
pull codes. Check fuel regulator. make sure pump is always priming. check fuel pressure.
Well how do i pull codes? That is the reason i am on here i have checked my wireing i havent checked my fuel pump becuase i can smell the fuel but if you think that could be why it dosnt restart sure ill check it. thanks.
