My 86 bronco's wiring harness is shot. i am kinda of on budget and was wonderring if anybody knew of anything. it is the harness from the cpu to the engine i have wires grounding out and bare and just to much of a mess to splice on. if anybody has any info please help
yo,
I think I have an idea of what he needs.
EFI Harness Rebuild Kit by Ryan M (Fireguy50) at http://rjminjectiontech.com/?p=16
EFI Harnesses by Ryan M (Fireguy50) at http://rjminjectiontech.com/?p=14
60 pin EEC-IV connector - $20 (terminals not included) Limit 1 per customerPigtails & Connecters by Ryan M (Fireguy50) at http://rjminjectiontech.com/?p=10
etc. contact Him at that site.
But I'd pull one from a yard
EZ-2 Wire Installation Info in an 84
Source: by justshootme84 (Randy Z, Casual Mudder) at http://broncozone.com/forums/index.php?showtopic=12864&st=0#entry71432
also in same URL is a Ron Francis Harness Review
Source: by Seabronc (Rosie, Fred W) & Broncobill78
For a YARD SEARCH on-line, I use;
http://www.mypartshop.com
Select year, etc, then FORD TRUCK
I used NY area
I selected Engine Wire Harness
Model Part Classification
Part Description Mileage Stock#
Part# Cond Code Ret Price Dist Buy Online Vendor Information
86 BRONCO
got 5 hits they give ya Phone numbers and address of each yard.
Then you can get the Wiring Diagrams in Haynes Manual or online at Local Library if you get a card.
and I have some diagram Links in my site, such as;
EEC Relay Wiring Diagram in an 86 5.0
Source: by Ryan M (FireGuy50) at fordfuelinjection.com
Truck EVTM’s
1986 F-150 5.0L pg60
1986 F-150 5.0L pg61
1986 F-150 5.0L pg62
1986 F-150 Ignition pg29
1986 F-150 Fuel System pg103
all by Ryan M (FireGuy50)
Wiring Diagrams in an 86
Source: by Xris at SuperMotors.net
Page 2 shows the EEC
& Ground Locations in an 86 (see #5); G701 Behind IP near RH side of radio; G801 On LH inner fender behind headlights; G802 On RH inner fender behind headlights; G903 At LH side of rear crossmember; G909 at lower LH cowl access hole; G1003 On LH side of frame behind front crossmember; G1006 Rear LH side of frame at rear crossmember; G1303 at LH radiator support
Source: by Seabronc (Fred W (Rosie) at Ford Bronco Zone Forums
yw, that's great!
Will you take pics of the install and post here, in FSB?
