1 - 20 of 31 Posts
I decided to start my build thread. Right now I'm more in the resurrection stage. As I have purchased it for $600 from a man off craigslist, knowing it wasnt running well.
Pictures are uploading now
Discussion Starter #2
Day she came home engine bay shot
Sat under a tree for 6 or 7 years. Paint needs love
Plenty of buffing compound later
Pulled out pounds of tree crap and nasty stuff. Should drain better now
shiny!
That was last weekend after the head job which I hadnt mentioned yet. Turns out it overhead a week after i got it running decent.
Heres some pics of the head job
Dismantling
Wow what a NASTY mess in there........where are you with it now......total rebuild, heads......?
Good Luck ~ :thumbup
Discussion Starter #13
Heads got redone. I have pictures just too much to catch up on in one day. Im still trouble shooting some cooling issues. New rad, fan clutch etc
Clean all that up and it should be good to go. Do frequent changes and it should slowly clean up the rest of the motor. Maybe add some atf the last 10 miles before the next oil change is due. Don't add or run atf too long, it might cause the oil pump screen to clog.
I would go with Sea Foam in the crank case for 50-100 miles then change oil/filter and repeat same if necessary so the internal oil pump, tube and screen get cleaned as well......tricky with all that inside build up you know!
Discussion Starter #18
Just bought my can yesterday :rockon
Discussion Starter #19
i live in va beach, not far from the mud hole you found...aragona village (near haygood). i'm a ff in norfolk at fire station #9 (thole street at granby) so we respond to your neighborhood.
Cool beans man. We'll have to go out to the hole sometime
1 - 20 of 31 Posts
