I'm at the end of my rope on this one and could really use some input. Vehicle is an '87 Bronco/302EFI/C6.
Problem is I can only get about one start every 12 hours. When it does start, it runs fine and has never died on its own. So far it appears it would run for days and days as long as you never shut it down. You don't even have to get up to operating temp - start it, let it idle for 30 seconds, shut it off and forget it; you might get it to restart 6 hours later.
CODES: only codes I'm getting are for insufficient EGR flow and open VSS circuit. Regarding the EGR, I don't care and I know why - the tube which feeds the EGR is packed solid w black soot. Regarding the VSS, I've never before encountered this, but I swapped in a different VSS just in the interest of due diligence. I then cleared the codes but have not since checked to see if the VSS code remains.
FUEL: I hear at least the hp pump prime when I turn the key. I'm a little unclear on the dual pump abortion pre-'90 but the fact that it primes, starts once a day, never stumbles while running and never dies on its own makes me think pumps are not the issue. FP while cranking is 39psi but I've not been able to check FP when running.
It does smell very rich when cranking which leads me to:
IGNITION: using both the shock-yourself-with-a-screwdriver technique and a HF in-line ignition tester, I do see (and feel) spark while cranking during no-start episodes.
Today I pulled the plugs and they were all oil-colored altho not really oil-soaked. They smelled very strongly of fuel. Given the low cost I simply replaced all the plugs today, but no change in symptoms. While the plugs were out I ran a dry compression test and got 125 to 140 in all cylinders (better than I would have expected).
I've also swapped the cap and rotor as the existing ones were in poor condition.
Early on I replaced the TFI module as you'd be remiss to do not so anytime such a problem appears on these vehicles IMO. No change.
Given the fuel smell and appearance of the old plugs I'm still suspecting something w ignition, but all that seems to be left is coil, which is easy enough..........but I'm not confident it's the issue. Would a bad or weak coil only allow one start per day but never cause the vehicle to die while running???
OTHER THINGS I'VE DONE:
-replaced the TPS as I had a bad TPS cause almost identical symptoms on a '95 351, altho in that case I was getting a TPS code and here I am not. No change from new TPS.
-swapped the IAC in an act of desperation - no change
-swapped in a different MAP sensor - no change
-visually looked for obvious vacuum leaks, and am surprised that all the vac lines appear to be in very good condition. Have not checked w starter fluid, however.
I'm open to other theories. Maybe something w injectors leaking down when I shut it off? Alien conspiracies? Still a sensor issue? What else is the EEC looking at for start parameters?
