I described this thing in another thread,but it was in the wrong place.(thanks for the assist,redwagon)
My '87 was running perfect until about a week ago.It was holding a smooth and steady idle at about 650rpm,when it suddenly just started missing,surging up to about 1500rpm,back down and then stalling.When that happens,it fires right back up,but runs the same.It does seem to get a little worse the longer it runs at operating temp.
Because the distributor is fairly new(4 months),I thought maybe it worked itself loose,but it didn't.
I threw a set of plugs,cap and rotor on it since I had them in the garage but that caused no change at all.
After checking whatever vacuum lines I could find,I sprayed the intake manifold and carb base with starting fluid but couldn't find anything wrong there either.
The check engine light came on after that,but then it went out.:banghead
What can I do to diagnose and fix this mess?
Any help at all would be greatly appreciated.
I forgot to mention,the carb is a rebuilt replacement(4180?) and the wires were changed at the same time.That was in July.
