so my 87 bronco only likes to start when its not been driven for a couple hours. if i let it sit over night and go out in the morning, it'll start right up over and over until it's hot. after i drive it anywhere and the motor is nice and hot, it won't start again after i shut it off. it sounds like it's a dead battery which doesn't make sense because the gauge reads about 12-14V. i've already replaced the battery, alternator, voltage regulator, solenoid and the battery cables. any ideas???
Have you tested the starter? My '87 was doing pretty much the same thing. After reading and testing, I got to the starter. I drove it till it warmed up and wouldn't start. I took the starter off after letting it cool down just enough that I could get to it. I then took it to the parts store for a test. It tested fine for the first test, so I had them do it again. Second test was good also. On the third test it started smoking. Got a new starter, put it in, and haven't had that trouble again.
A caveat (is that the right word?): don't rush out and change your starter just because that was my issue. Test it first.
Choosy bronco
Thanks for the advice. I didn't think the starter would be an issue mainly because it starts just fine when it's cold. But I'm will go try anything so thanks for the advice.
a little more info is needed.
won't start means? won't crank over? Slow to crank over? Cranks over fast but does not light up?
I have a 96 and on when it's cold it struggles with a slow crank, but consistently turns over. However, I have the same problem. When I drive it for a while and the motor is hot, I get nothing when I turn the key. Battery is fine, alternator is charging. Thoughts?
Im not sure if your 87 was part of the recall but my 95 had a recall for the starter ground wire. I cant remember the details exactly but essentially the connector for the ground wire was sub par and it would cause the starter not to engage. I didn't know about the recall so before I fixed it I would crawl under the vehicle and smash the starter with a hammer until it would finally engage :histerica Obviously this wasn't a fix but as a new bronco owner I didnt know what to do at that time. After I heard about the recall I again went under the vehicle and crimped a new connector for the ground wire and haven't had an issue since! Apparently my banging it with a hammer hasn't impacted the performance of the starter :goodfinge
Sounds a lot like OP's question. Try doing what others and myself have suggested before asking. :twak
Do you have a heat shield on the starter? mine suffered from heat soak that made it seem like the battery was dying after I stopped for gas. I put an aftermarket soft heat shield on the starter and it's fine now.
