I purchased this Bronco about two years ago. Am now trying to get it road worthy, before I go offroad.I had already replaced the alternator, solenoid, and have just put in a working transfer case. Been driving but having starting problems once warmed up. Decided to do a good tune up, as it has sat quite a bit. Picked up plugs, wires, cap, rotor, coil, fuel filter, Oil & Filter. I had put a Pint of seafoam into the gas and oil on the last fill up. I had just filled the tank, and as i went to leve the parts store. It decided to take a big crap in the parking lot. After about 15 minutes af attempts, I jumped out and went to pull the fuel filter. I pulled the carb side first, and fuel came out but not all that much. When i pulled the other side off had a lot of back pressure and sprayed out. I put the lines back on started right up. After getting home began on my project. The cap on my existing coil was broken (PO, left me many surprises:twak )
I have my battery at the parts store charging right now, and am getting ready to change my battery cables. I am lookin at gettting a new cap for the coil hoping I can get by with just rigging it for now.
I also am swappin my light switch in hopes I can get dash lights once again. I am hoping to get this set up by summer with a lift, and going through front suspension. Lots of plans,
"I know that Im a dreamer, but Im not the only one!" John Lennon
"I get by with a little help from my friends!" Ringo Starr :rockon :rockon
Thank you FSB for the help and info as this project progresses
opc1:
