Hey guys. I'm new to FSB and to the 4x4 scene actually. I picked up my first bronco for only $400. When I bought it the previous owner wrapped the chassis harness around the front drive shaft. :doh0715:I figured this would be an easy fix. The bronco came with a 2 inch body lift and a set of 33x12.50x15's. Not a bad start I thought. After getting her into a shop I pulled out the spark plugs and checked for water, luckily there was no water. Then I checked the oil, and I almost freaked out. There was only a trace of oil on the dip stick and some dirt. After seeing that I pulled off the intake system to see if there was and traces of dirt in the throttle body. I didn't see anything but just to be safe we pulled off the Plenum and checked the intake manifold and didn’t find anything but carbon build up. There are no front seats but the rear bench was just lying in the back. So far this has what’s been accomplished.
-front and read drive shafts have been dropped.
-removed transfer case
-started stripping interior
-bought new chassis harness from Pick-n-Pull.
-transfer case has been torn down and awaiting over haul kit.
Me and a couple of my buddies have started running the wiring harness that we pulled from another bronco. So far we just have the taillights, license plate lights and fuel pump hooked up. This coming weekend we will be getting back to business installing the rest of the wiring harness.
To do list this weekend.
-finish chassis harness
-install throttle body, plenum, and new oil pan gaskets
-clean oil pan and install new oil pump.
-pressure wash chassis and engine bay.
Last weekend I pulled a 6 inch skyjacker lift off of an 89 bronco from the Pick-N-Pull, all together it came out to around $50. But we were unable to get the axel drop brackets because they were welded to the frame. But we will be heading back to try and cut thru the welds with some cutting wheels I got from sears. Does anyone know another way we could try and cut the welds? Keep in mind we don’t have access to air or power...also does any one know where I can find a DIY guide to over hauling a 13-56 transfer case?
I will post pics of all the progress after this weekend. My computer crashed a few days ago and I just got it up and running :banghead
