1 - 2 of 2 Posts
Selling my '88 Bronco XLT- I have the '78 to work on now. Here's the run down:
about 160k miles. It's at my parents house - ill have to check exact mileage
Auto trans with B&M shift kit - towing/off road
302 V8 with Crane PowerMax Truck Power cam, throttle body spacer
3" high flow cat to 3" in/dual 2.5" out Holley Terminator muffler
cone air filter
Motorvation piggy back chip to work with cam and exhaust
Ford limited slip front and rear with 4.10 gears
31" Kumho Venture M/T tires
Warn manual lock hubs
custom rear bumper with D-rings (in-line with frame mounting points), back up lights, and receiver hitch
wolo air horn
driving lights
wiring for fog lights
lighted cab visor
Interior
Bucket seats from 96 F-150
custom center console with 10" sub and amp - hidden in console, with locking compartment on top
flamed headliner
cerwin vega component speakers in front doors
pioneer 6x9 speakers in rear
stereo has been removed
Brakes are good. no oil or fluid leaks. starts and runs good. cruise works. recently replaced power steering pump (junkyard unit), differential electric motor - new unit
Known problems -
A/C doesnt work
fuel gauge doesnt work- most likely sender problem
needs alignment and power steering gearbox - very loose steering. i have replaced any suspect ball joints and tie rod ends - the play is in the box
some rust over rear wheels. wheel wells have been repaired with fiberglass from the inside to keep water, fumes, etc from entering the cab
passenger side door bottom rusty
intermitten problems getting tailgate window to work. key in tailgate *usually* works. dash switch does not
Asking $1,200. No trades. Make an offer, and I'll think about it - need to get money to throw into my '78 as spring is on its way!
Discussion Starter · #2 ·
Anyone want to see additional pics or make an offer, let me know - post or PM.
Located right between Binghamton and Albany on I-88.
1 - 2 of 2 Posts
