1 - 20 of 49 Posts
I've been talking about doing it for a while, now it's time. I'll keep a updated list of the parts that I used. I did the Rear bumper first and then went to the front. So if you're interested in the front bumper skip to page 2.
Parts List:
4x6 steel rectangular tubing 6'
2 - 1x2 solid steel bars 11"
extra 3/16 steel plate
Ruff Stuff DIY Custom Bumper Fabrication Package
2x2 steel rectangular tubing 4'
I decided to use the mounts from the old bumper. I cut them off and welded steel bars on. These are going to be my main supports and go all the way through the bumper so I can attach D-rings on them on the other side.
First test fit looks good
I then cut triangles out from either side and bent the bottom up. I then welded them together. Note: the bumper is upside down in the pic.
Drilled some holes and welded in the spindle for the spare tire swing arm.
1 - 20 of 49 Posts
