1 - 4 of 4 Posts
1996 F350 EFI 460 Conversion engine, bone stock internals, runs like a clock
L&L 460 conversion motor mounts
AGR Power Steering Pump with ram assist
Dual batteries with battery isolator
K&N air Filtercharger, MSD 6AL Ignition, MSD plug sires, Accel Coil and Dist cap
EFI 460 engine harness converted to mate to 1989 Bronco firewall
EFI 460 mated to factory F350 E4OD Auto Transmission and Borg Warner 1356 Transfer case
Custom Driveshafts front and rear
B&M Trans cooler, B&M Trans shift kit
Custom mounted Volvo AC Compressor converted to provide On Board Air, 7 Gallon Air tank mounted forward of the fuel tank provides 125 PSI of air for running air tools, inflating tires. Front and rear quick connect air connections
Reverse Rotation High Pinion Dana 60 HD Front Axle, Richmond Gear 4.56’s plus ARB Air Locker, ruff stuff diff cover, new yukon hubs and 35 spline chromoly shafts
Custom Trac bar drop bracket, HEIM Joint Tie Rod Ends
Custom Power Coated 3-link suspension with HD Heims, over 24” of front travel, extremely soft suspension
Quad custom mounted Rancho RS9000 Long Travel In-Cab Air Adjustable shocks
F350 Ford 10.25” Full Floater rear axle with Richmond Gear 4.56’s and ARB Air locker
Re-worked rear leafsprings for flex provide very soft suspension
Aluminum High Capacity diff cover with Purple Cranium Half Spider diff rock guard
Quad Rancho RS9000 In-Cab Air Adjustable Shocks
Welded rear leaf spring lift perches, Drum Brakes
Custom Rock Sliders
Custom Rear Swing Away Spar Tire Carrier
Custom Front High Clearance front bumper with warn 9000 high speed
Custom rear HD bumper with welded shackle mounts
XLT interior in decent shape, Power windows, Front cloth Captain’s chairs and rear fold-and-tumble bench seat, some wear on driver’s seat and rear bench seat, carpeting good, dash good
Overhead mounted 40 Channel CB
Full custom welded rear roll cage with Armstrong Armaflex padding and Roll Bar Rapz covers
Custom rear storage box
Autometer Gauges include Ammeter, Oil Pressure, Trans Temp, Vacuum, Water Temp
Dash mounted On-Board Air control pressure gauge
Console mounted Rancho Air Adjustable shock control panel
HELLA ATP Driving Lights, High Mounted Backup Light
Mini boatsides with 2x6 rectangle tubing
(5) 40-13.50x17 procomp mt’s on new raceline monsters. Tires/wheels have a couple hundred miles and 3 wheeling trips on them.
New, never installed softopper soft top.
Asking $11k PRICE DROP!! $8500
Located in Hammon, Ok
Fantastic deal! Couldn't build it for twice that.
1 - 4 of 4 Posts
