1 - 15 of 15 Posts
well the nine never came with a drain plug. you can either add one, or try sucking it out the fill tube.
but if your puking chocolate milk I would pull the axles and clean everything out, then again your axle shaft seals will leak from then on.
you can't pull the diff out unless you pull the axle shafts.
I guess you could pull the pinion out, but you have to remember to put the shims back in.
good luck, I had a terrible time sucking the oil out of my 9 inch. I ended up unbolting the axle, and rotating it so that it would drain out the fill hole.
Administrator
never thought about it till you said it. I looked through some write ups, and I dont want to take the axles out cuz im sure I willl screw something up.
I still have your tool, not trying to keep it or anything
forgot about that, somewhere on my supermotors is a pic of the drain plug I installed in my 9inch before I swapped to the 14bolt, I probably still have the tap you could borrow.
Administrator
I looked at your pics,didnt you weld it?
No, drilled a hole off to one side of the housing, tapped it for a flush mount plug and done. I figured by having it off to one side it would be less likely to be damaged and if I needed to fully drain the housing I could jack up one side of the axle, If you your going to do it with the fluid in, just wrap the drill in a plastic bag and use a drill bit stop to keep from drilling to far into the housing.
I have found that pulling the pinion gear is the easiest way to go (if you don't have a drain plug) to change the oil in the 9". The shims shouldn't be an issue as the o-ring/packing will prevent them from falling off, but you will need to install a new o-ring/packing and put a light coat of RTV on the pinion flange before you re-install it to help prevent leaks. Just remember to put a drip pan under the pinion to catch the oil that will drain out when you pull it. Other wise you have a puddle of gear oil on the drive way and a pissed off wife - "it's a driveway, not the living room."
1 - 15 of 15 Posts
