i found a great deal on a 6" lift but it is for a 90-96 bronco and mine is an 87....i was wondering what the differences are? if its possible to use the lift on my 87
Thanks
Thanks
:whiteflag whats the difference?if your has dual shocks and it has single front shocks or vise versa you would be down 2 shock, or up 2 shocks(if it comes with shocks), but its 100% bolt on for an 80-96 f150 or bronco
also a little secret, the 90-96 don't make since
80-86 was the 2nd gen for the fs bronco(or 3rd gen bronco )
87-91 is gen 4
92-96 is gen 5
so your 87 is basically the same as the 90, minus some wiring(maybe) and the transmission which falls in the 90-96 list which is probably a typo to 80-96
if you get it, and plan on putting some bigger tires on there, and your 87 has manual hubs from the factory, i would look at upgrading them because 90% chance they are top hats
