1 - 8 of 8 Posts
90 Bronco, 4.9 inline, 5 speed mazda. skyjacker level coils + 4 shocks on 33x12.50 A/T on 15x10
hi yall, my wipers have had an issue, they will come on and work for about 2 minutes then they cut on and off. this happends at ant speed and with the variable setting. ive replaced the switch and the control box with no avail. any info? Thanks!
1980 XLT; 5.0L 347 stroker; C6; NP208; Holley Sniper EFI
Do they just shut off completely or does the speed/frequency change?
1990 Ford Bronco Custom, 5.0L EFI AOD Manual Hubs
Really stupid question but did 90 Bronco’s have intermittent wipers?
My '90 does. It is not like the "turn and click, click" for different intervals on the signal lever on newer models or F-series. More like a turn to click "on" and variable intermittent like an old style dimmer switch. Best i could describe.
~Erik
Yo Nater1836,
159839
159841
Interval Governor Repair in an 89 F 150
Source: by rusheadcarerra
Switch Replacement in an 89; "Went to advanced, spent $20, and got a non delay switch. Plugged right in and worked. Swapped out the wiper motor as well, since it was really noisy and I had one laying around from a parts truck. And found out that the previous owner replaced it as well (junk yard markings), and it had the wrong connector. There's a 3 pin connector on the bottom, and a 4 pin on the forward side. My truck only has 2 3pin harnesses. He just crammed the 3 pin connector (which was molded different as well) into the 4 pin spot... LOL. I'm surprised it worked at all..."
Source: by Madcat455
TSB 95-8-2 Wiper Motor
Publication Date: APRIL 24, 1995
FORD: 1986-94 TEMPO
1987-91 CROWN VICTORIA
1987-93 MUSTANG, TAURUS
1989-92 PROBE
1989-93 THUNDERBIRD
1991-94 ESCORT
LINCOLN-MERCURY: 1986-94 TOPAZ
1987-89 TOWN CAR
1987-91 GRAND MARQUIS
1987-93 SABLE
1988-94 CONTINENTAL
1989-93 COUGAR
1991-94 TRACER
1993 MARK VIII
LIGHT TRUCK: 1987-94 BRONCO, F SUPER DUTY, F-150-350 SERIES
MEDIUM/HEAVY TRUCK: 1980-94 L SERIES
1988-95 F SERIES
ISSUE: A revised service windshield wiper motor is now available, if the windshield wiper motor requires replacement.
ACTION: Replace the wiper motor with a revised wiper motor and use a Windshield Wiper Motor Service Kit to complete the installation. Refer to the Application Chart listed in this article for the proper application. Follow the detailed instructions included in the service kit.
1. Inspect the vehicle to see if the new Wiper Motor (-1750:cool: is already installed. If so, the latest level of wiring is already installed and the Wiper Motor Wiring Kit (-14A411-) is not required.
2. Install a new Wiper Motor Assembly. Refer to appropriate Service Manual for installation details.
3. Use the Wiper Motor Wiring Kit (-14A411-) if necessary to complete the installation. The Wiring Kit (-14A411-) consists of:
  • One (1) Wiring and Connector Assembly
  • Seven (7) 5/16" (8mm) Heat Shrink Tubing - 2" (51mm) long
  • One (1) 37/63 (lead/tin) Solder 0.032" (0.80mm) diameter x 12" (305mm) long
  • One (1) Adhesive Label
  • Instruction Sheets
Not included in the kit is the Wiper Motor (-1750:cool:.
Application Chart
Model Year Vehicle Wiper Motor Wiper Motor Wiring Kit
1987-91 Grand Marquis, Crown Victoria F5AZ-17508-B F4PZ-14A411-B
1987-93 Taurus, Sable F4DZ-17508-B F4PZ-14A411-B
1988-94 Continental F4DZ-17508-B F4PZ-14A411-B
1989-92 Thunderbird, Cougar F4SZ-17508-B F4PZ-14A411-C
1993 Thunderbird, Cougar F4SZ-17508-A F4PZ-14A411-C
1987-93 Mustang F5ZZ-17508-A F4PZ-14A411-C
1993 Mark VIII F4LY-17508-A F4PZ-14A411-B
1991-94 Escort, Tracer F5CZ-17508-A F4PZ-14A411-C
1986-94 Tempo, Topaz F43Z-17508-A F4PZ-14A411-C
1989-92 Probe F52Z-17508-A F4PZ-14A411-B
1987-89 Town Car F5VY-17508-A F4PZ-14A411-B
1987-94 F-150-350, Bronco, F-Super Duty F5HZ-17508-A F4PZ-14A411-C
1988-95 F-Series (Med/Heavy) Built Before 8/1/94 F5HZ-17508-A F4PZ-14A411-C
1980-92 L-Series Built through 11/26/91 F5HZ-17508-C F4PZ-14A411-C
1992-94 L-Series Built from 11/27/91 F5HZ-17508-B F4PZ-14A411-C
PART NUMBER PART NAME
F4PZ-14A411-B Wiring Kit
F4PZ-14A411-C Wiring Kit
F5AZ-17508-B Wiper Motor
F4DZ-17508-B Wiper Motor
F4SZ-17508-B Wiper Motor
F5ZZ-17508-A Wiper Motor
F4LY-17508-A Wiper Motor
F5HZ-17508-C Wiper Motor
F5HZ-17508-B Wiper Motor
F4SZ-17508-A Wiper Motor
F5CZ-17508-A Wiper Motor
F5VY-17508-A Wiper Motor
F52Z-17508-A Wiper Motor
F43Z-17508-A Wiper Motor
F5HZ-17508-A Wiper Motor
E92Z-6102316-A Retainer
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 94-11-20, 95-4-6
WARRANTY STATUS: INFORMATION ONLY
Real common on those is the back part of the switch. It mounts upside down in the dash. There is a solder joint that gets loose which affects low speed and intermittent function, though high speed works well. If your issues are only low and intermittent functions, remove that and carefully check those solder points on the board.
Thanks everyone, im not dead set on having intermittent so would going to low and high speed only be a more reliable fix? ive replaced both the switch, motor and control box to no avail.
Ford sometimes uses a circuit breaker instead of a fuse on the windshield wipers. Check the fuse panel and if it’s a circuit breaker replace it with new. They can weaken with age.
1 - 8 of 8 Posts
