90 EFI convert to 94 MAF
637 Views 3 Replies 3 Participants Last post by  90.CaliBronco
Hi all, been combing through all the posts, but can't find the one I read a few weeks ago that was a pretty good write up on someone converting their 90-92 bronco to MAF and if someone can help me by linking that write up, it would be much appreciated.
In the mean time I found a local yard with a 94 F-150, looked up the VIN and it has a 5.0 w/MAF, automatic trans and 4x4.
I have a 90 Bronco with 5.0 EFI, w/E40D trans. if i find out the 150 has an E40D, is that an easy plug and play swap? What parts do i need to take from the f150?
My parts list as I've gathered so far is (can you add to it for whatever else I need?:
  • EEC
  • Complete Wiring Harness
  • Air intake components
  • Mass air sensor.
Thank you!!
1 - 4 of 4 Posts
Yo 90,
Welcome!
MAF Upgrade in a 90 - Lessons Learned Thread, by Seattle FSB @ MAF Upgrade - Lessons Learned Thread
Includes his MAF Upgrade. Seattle FSB 408 Stroker Build
I believe he answers yiur question, such a the EEC. I'd post them, howver I get lag here in FSB.
Here are the 1990 Bronco Pre-Delivery Shop & Electrical & Vacuum Troubleshooting Manuals (EVTM), Partial by member Kingfish999 in Google Drive @ 1990 Ford Truck service manuals - Google Drive
Suggest you download for faster scrolling and to use the table of contents index.
1990 Ford Bronco Brochure, partial by El Kabong @ 1990 Ford Bronco Brochure pictures, videos, and sounds | SuperMotors.net
Register with VIN to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site
Look @ Baba Looey's Favorite FSB Links (lots and lots of tech links)
As you've done, for any Bronco issues or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories that requires 75 non-padded posts to participate due to scammers who preyed on our members.
Our Forum FAQs includes for example: How To Upload Images To Posts, How to Use Search and more tips!
Try to find time to participate and vote in our Full-Size of the Quarter & Full-Size of the Year Contests @ Voting
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
I know you will enjoy our site!
Al
far from plug n play. the wiring harnesses changed dramaticly in 92 so everything would need to be spliced in. and thats alot of wiring and figuering out. instead of swapping the wiring, its almost easier to repin your old wiring for the new PCM and then add the wires missing.
the 94 uses PSOM in the speedometer and rear axle ABS sensor to determine vehicle speed. 91 and older use the gear driven sensor in back of t-case for that. so without tuning you would have to rig up a PSOM and wiring to rear axle to make it work. this is needed for trans to shift correctly.
im blanking out right now but theres alot of issues doing that swap and unforseen issues.
you could use a Fiveology MAF kit. defiantly more expensive but more proven to work
Awesome thats the one!! thanks for the info!!
1 - 4 of 4 Posts
