1 - 2 of 2 Posts
yo Dog;
According to motorcraft you have the
1991 Ford Bronco Fuel Pump
Manufactured By: Motorcraft
Part Description: Requires Jumper Harness. See Part Description - Fuel Pump Jumper Harness, For Part
Part Number: 9A407 (PFB-4) from Ford Motorcraft
From Fuel & Emission Parts Catalog, Bronco/Ford truck & all Fords w/Ford Part Numbers, Illustrations, Carburetor Tag Numbers & Cross References
Source: by fordinstallersupport.com
PFB-4
Fuel Pump & Bracket Assy.
LIGHT TRUCKS
FORD TRUCK .............................................1996-90
Buyer's Guide Results from Ford Motorcraft
Part Number: PFB4
Description: Fuel Pump
Manufacturer: Motorcraft
Years: 1990-1996
Applications: 17
Years Make Model Engine Qty per Vehicle
1990-1992 Ford Bronco All Engines (3) 1
1993-1996 Ford Bronco All Engines (2) 1
I thought there would be more interchange but that seems right now; here is what the E & F Series used in 91 as an example;
Fuel Pump & Bracket Assy. ............................................................ (Bronco) ................................................................................................. PFB-4(38)
(F Series) 17 Gal Midship Tank ................................................................ PFB-1(38)
(F series) 19 Gal Midship Steel Tank-2 Tube Ports ................................... PFB-2(38)
(F series) 19 Gal Aft Axle Plastic Tank ..................................................... PFB-5(38)
(F series) 18 Gal Aft Axle Steel Tank ........................................................ PFB-3(38)
Fuel Pump & Sender ...................................................................... (E Series) w/Midship Tank ....................................................................... PFS-26
(E Series) w/Aft Axle Tank ....................................................................... PFS-90
(E350 Cutaway) w/Aft Axle Tank ............................................................. PFS-90
1 - 2 of 2 Posts
