I have been reading everything which I can find on this board about exhaust manifolds and headers for Broncos... but still have a couple questions...
I just bought this truck 3 days ago, while going over the truck I have noticed a cracked exhaust manifold on the passenger, side which explains the exhaust sounding leak which it had when purchased..and the "rumble in the exhaust on deceleration" which I am assuming is backfiring in the exhaust due to cold air being sucked in the cracked manifold.
there is no carbon foulding around the crack on the exhaust manifold, at least on the visible area of the manifold... do these manifolds have a tendency to crack and not leak? as I have read somewhere else that another possible area of leakage is the EGR tube on the back of the motor, which I will check out tomorrow more clearly....
Given that there is a crack in the passenger side manifold I am assuming I need to replace as I had said when I back out of the motor it is definately sucking back in and causing some type of detonation..you can hear it through the exhaust.
Driver side manifold seems to be fine, should I just replace the passenger manifold with one of these replacements? http://broncograveyard.com/bronco/i-30005_exhaust_manifold__302_right_w__o2_hole.htmhas anyone on the board used one?
or should I just get a set of hedman headers and replace both manifolds while I am at this? the only thing which I am hesitant about is breaking bolts in the head, I have not dealt with that before.... I have been soaking the bolts everyday in PB Buster in anticipation of this repair...
also if you suggest headers, do you suggest painted or ceramic coated? I know ceramic coated retain heat better/wont rust, etc however I only need these guys to last a couple years until its time for a motor overhaul...
Please let me know what you guys think and I appreciate the help!!
