1 - 1 of 1 Posts
I purchased a '91 302 AOD that is stock except for Warn hubs and 32'' tires. The truck has 135k on it w/ an engine rebuild at 125k.Sat-up for 6 mos. before I bought it.
First problem. It sputters when taking off slowly.
Facts:
Only does this at normal temp range
Runs great at idle and hard acceleration
Garage said fuel psi is @ 20 when it should be 40psi
Garage wants 700clams to R&R both fuel pump & regulator
Is the garage right or should I just replace the regulator by myself?
Second problem.Push button won't engage low range. Can I prove this out with a test light?Could the selenoid be stuck from lack of use?
Thanks for any help on this
Tim
1 - 1 of 1 Posts
