So, I think I burnt the pcm in my bronco due to sending power down the signal return wire from the diagnostic port. Truck ran real rough not able to hold an idle afterwards and then after sitting overnight it won't restart. I checked the obvious like fuses and stuff and found no issues there. It is getting fuel pressure and spark (although unsure if the timing is right). Truck had no real drivability issues prior to the power to the ground issue. After some research I have dug up the following test for the pcm.
you need to check for B+ at Powertrain Control Module pins 1, 37 and 57. If no voltage, trace and repair circuits as needed. Check for good grounds on pins 40, 46, 49 and 60, repairing circuits as needed. NOTE: pin 46 is a sensor ground that connects internally in PCM to pins 40 and 60. If 40 and 60 are OK and 46 shows voltage,the PCM will need replacing. Check for constant5Vreferencevoltage at pin 26. If voltageis low, disconnect Manifold Absolute Pressure sensor, EGR valve position sensor and Throttle Position Sensor replacing any sensor thatallowsreferencevoltage to return. If voltage remains low with sensors unplugged, cut the Brown/White wire of pin 26 near the PCM connector. Check voltage on the PCM side of wire and if 5V now present, trace the wire to locate and repair short to ground If voltage remains low out of PCM and all powers and grounds check OK, replace PCM.
So, after I get my dmm from work tomorrow I will be testing the pcm and will update this post with my findings. Hopefully at the least this post will help others in need of testing their pcm.
