1 - 10 of 10 Posts
I searched and only found one thread that dealt with swapping a 92-93 column into an older Bronco--and there was no closure:cry
My question is this: Has anyone swapped a steering column from a 92-93 into a 91? I know the wiring issues involved if I want the OD cancel button, high beams, and wipers on the column-but how do they match up physically?
The reason I'm considering this is because I've got some isues with my column right now (steering wheel pulls down easy w/out using the lever and now my ingition switch won't work to shut the Bronco off---it turns but nothing happens(I don't think being -31 outside helped much)):banghead So, instead of tearing apart the existing column I thought about swapping a newer column in place of the worn-out one.
Any ideas, thoughts, concerns, advice, and sarcasim is welcome:toothless
It's BTW Not AKA!
I would think you would need the whole dash. Since the two columns arent even remotely the same shape.
Banned
The wiring is the LEAST of the problems. The short answer is: FORGET IT. The long answer is: take LOTS of pics! ;) :thumbup
I knew that they were different--I had a 96 F-150 at one time. I haven't had a chance to get side by side with a 92+ to look at the differences since I thought about this though.
So, what your saying is if I'm crazy enough to try it-record my impending failure.
Discussion Starter · #10 ·
Ding Ding Dig, we have a winner :thumbup
...let me know if you EVER drive it closer to me than Iowa so I can climb a BIG tree before you get here. :rolleyes:
Thanks for not lighting me up too bad---even though I did ask for the sarcasim:toothless
:whiteflagI guess I'm just going to have to tear this one down and fix the tilt, blinker cancel, ingition switch, and overal loosness.
1 - 10 of 10 Posts
