Well, last night when I was trying to "fix" my interior rear window switch(still doesent work). I did something wrong because now my blinkers nor hazards work. Checked fuses. Any ideas? Also the bronco has the "push button" 4x4 with manual locking hubs. I locked in the hubs but the interior switch in not engaging."what-ever". This could be related to my blinker problem. I dono?
1992/302/auto
Also where is a good place to buy replacement interior parts for a 92 bronco?
Discussion Starter #2
got the blinkers
Those electronic shift motors are notorious for going bad. Right when you need them the most. Easiest fix is to tap the shift motor a couple of times with a hammer (just like you would a starter). The contacts on the motor get full of carbon buildup so tapping it sometimes clears those contacts enough for it to work. You'd be surprised.... it might work for you. And its the cheapest solution too... before you try any other solutions.
