1 - 4 of 4 Posts
Had a leaky rear main in my 92. Replaced it and got the tranny back in. How do I got about refilling the tranny with fluid? And do I need to do anything to refill the bell housing with fluid? Thanks.
A/T, fill through dipstick tube. M/T, fill through port on driver's side.
The bellhousing is dry in both cases. The torque converter in the A/T bellhousing holds fluid, but not the bellhousing itself.
Yo Tkwilson115,
WELCOME!
"Add 6.2 liters (6.5 quarts) of fluid to the transmission through the fluid filler tube.
Start engine. Move the transmission range selector lever through all gear ranges, checking for engagements.
Check and adjust the transmission fluid level in 0.24 liter (0.5-pint) increments to the proper level (cross-hatched area of the fluid level indicator (7A020) at normal operating temperatures)." by Ford
Here's the 1992 Bronco Dealer Brochure @ http://www.auto-brochures.com/makes/Ford/Bronco/Ford_US Bronco_1992.pdf
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view, due to scammers who preyed on our members ).
Register with VIN to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site
Our Forum FAQs includes for example, How To Upload Images To Posts, How to Use Search and more tips!
See Baba Looey's Favorite FSB Links (lots and lots of tech links) ... includes such as, "Tailgate Window repair & troublehooting".
➡ Try to participate and VOTE in our ongoing Full-Size of the Month Contest & lster in the year, Full-Size of the Year Contest @ Voting
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Al
New day new problem. Truck was turned off. And on jack stands. Took the shifter from park to 1st gear. Now it won't come out of first. Any ideas?
1 - 4 of 4 Posts
