Hi Pick-a-part,
I'm looking to do something similar to what you described. I was thinking of going the 2" route, just to avoid the possibility of lengthening my driveshaft. However, I have to agree that it probably makes sense to go with a 4" given the trouble and expense. JBG has a 4" kit that looks good. I have a couple of questions if you don't mind: First, did the 4" lift require you to lengthen your driveshaft? Also, you mentioned JBG drop brackets and JBG extended radius arms. Did that combination eliminate the need to move the stock brackets on the frame? My understanding is that typical combinations are either stock length radius arms with drop brackets or extended radius arms with relocated stock brackets. However, I would prefer not to drill and move the stock brackets if the combination you mentioned will work. Lastly, which front and rear Pro Comp shocks did you get for the 4" lift?
Thanks,
John
