hey i got a 92 FSB 5.0 5spd and it's got a power surge from somewhere. my cousin thinks the ECU is going bad. it'll start and run. if you turn it off when it's warm it won't start back up until it's cold. i've already swapped out the ignition module for a new one though and it still does it. it just won't pop. it's getting plenty fuel.
while it's running, every 3-4 minutes or so it'll get a surge. the only gauges it affects though are the volt and tach. the tach gauge will raise up 1200rpm(not the engine, but the tach itself) and the volt will drop to about 8-9, just for a second. and then go back to normal.
if i roll into the throttle it'll do ok up about 42-4500rpm but if i stand on it, it starts to run like [email protected] (misses alot) at around 24-3000rpm. it's got a new distributor in it. my cousin put it in while i was overseas to see if that would help. it kinda feels worse though now.
please help oh guru's of the FSB!!
thanks
thanks
