92 Stroker Frame Off Restomod
89372 Views 688 Replies 47 Participants Last post by  Burntoutaccountant
Edit 2023
I thought I would add what components this rig has at the beginning for easy reference.
97 351w roller block bored, stroked, decked and balanced.
Eagle 408 stroker kit
Keith Black pistons
Comp Cams Xtreme Energy Hydraulic Roller Camshaft 35-351-8
AFR 185 heads
Edelbrock 3881 intake
BBK 61mm throttle body
High volume oil pump
Crane cams 1.7 Cobra roller rockers
BBK fuel rails and regulator
Bosch 42lb injectors
Bassani shorty headers and full exhaust
10.5-1 compression
Sagnaw power steering pump with 4 bolt steering box
TRE flip
D50 stub
ARB lockers
4.56 Yukon gears
Threat motorsports 4 inch cut and turned lift
HD TTB beam mounts
HD spring buckets with XL Bilstein shocks
Rear Deaver springs with rear shock relocation kit
Sanden 508 OBA with 4 Gal tank
Denny's HD 1330 rear drive Shaft
Rear disk brake conversion
Nodular 9 inch rear with pinion protection
6R80 conversion
Champion radiator with dual Spal fans
Pulse modulated fan controller
HD Derale stand alone trans cooler
F-350 booster&MC
Raptor Liner over epoxy primer
Modified Rock Solid rear bumper with rear quarter protection
Wild Horse/JB front winch bumper
New Vintage USA guages
Glow shift dual AFR guage
Pimpx/mega squirt ECU
MSD dual sync distributor
MSD 6AL ignition
Custom roll cage
Procar seats
Raceline Raptor 17*9 wheels
Dick Cepek Extreme Country tires
UMP AIR BOX
WARN 9000I WINCH with warn Spydura line
Polk Audio DB 6502 Front speakers
Sony XAV-AX4000 double din
Rockford Fosgate T1693 rear speakers
Sound Ordnance™ M75-4 amp
I think I am ready to start a build thread. I expect this to go slow. I have been gathering parts over the past months. I have also read a lot of info on here. I am starting with a bone stock 200k mile truck. No rust it's from Arizona. I picked up a 2011 6r80 and transfer case from a F150. I grabbed a 351 roller from the LJY out of a 97 250. It only has 76k. I am going to strip the block and have it machined for the 408 internals. I just scored some low mileage AFR 185s, BBK fuel rail, regulator and a Ron Francis mass air wiring conversion. I plan on running a Mega Squirt sequential fuel injection. I am sourcing the 408 internals currently. Nothing crazy I want TQ from idle to 5500. My brother is an engine builder so I gave him my requirements and he is selecting the cam and internals. I'll share when it's purchased. I am going to try to use the 2011 transfer case but need a slip yoke eliminator. I was thinking getting machine shop to drill and tap the output shaft and bolting the 2011 drive salt yoke to the output shaft then adapting that to the current driveshaft. Open for suggestions on this. I have also got a 9 inch from a 80's f150 that I plan to use for some extra strength.
Sent from my Pixel 2 XL using Tapatalk
Reactions: 2
641 - 660 of 689 Posts
Softball game for today was rescheduled. I finished wiring the console short of table switching buttons. I need to test the stereo before I seal it up so I thought I would throw the speakers in. I didn't realize the speakers I bought were 6.5" and the kick panels only accommodate 6" so careful modification was required. Time consuming too. I'll clean up the massive amount of wires in the console after I ops check everything and tune the amp.
View attachment 208817 View attachment 208818 View attachment 208819
how did you do the speaker panel? it looks good. I have one that is cracked and have wondered about getting them out of the door for rattle purposes and relocating ( plus component capability rather than coax)
They are Q Logic panels that I bought. I did not make them. Is that what you are asking?
4
I modified the rear speaker mounts to accept the new 6x9 speakers. I cut some 3/8" plywood to use as a spacer to keep them off the body. I also had to cut and bend portions of the mount to accommodate the frame of the speaker. I put the grills on to protect them until I get to refurbing the interior panels. The stereo sounds great but needs a sub IMO. I'm ordering a single 12" shallow mount Kicker L7T12 and 800 watt Kicker amp to drive it. I'll have to build an enclosure for it. I'm going to snug it in the driver's bedside at some point.
Camera accessory Audio equipment Gadget Cameras & optics Font
Automotive tire Audio equipment Gas Personal protective equipment Auto part
Blue Black Automotive tire Wood Chair
Automotive lighting Window Audio equipment Electronic instrument Font
O
Reactions: 1
OK I pulled the trigger on the L7 sub and amp. I will build the custom enclosure at a later date. I bought an enclosed version so I could fill out the sound. Man this system rocks! I mean really clear sound and the L7 hits hard. It is more than enough bass with the top off. Now on to closing up the console tiring up some loose ends and try to take her for a spin.
Automotive tire Motor vehicle Bumper Rectangle Automotive exterior
Reactions: 1
Here is the amp tucked in the back of the console. I love it when a plan comes together.
Automotive tire Motor vehicle Bumper Asphalt Vehicle
p
Reactions: 1
2
A buddy came over and helped me change out the beam pivots today. I had Threat motorsports HD stock drop pivots and I could not get the passenger tire into spec and the driver side moog adjustable bushing was maxed putting the ball joint at a bad angle. I just wasn't comfortable with that so I bought the Solo or Desolate(can't remember which) 2 inch drop brackets. Much better now. The mocked up Threat pivots will be in the classifieds shortly.
Hood Automotive tire Motor vehicle Automotive exterior Bumper
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
I picked this up yesterday. Hmmm, I wonder what I can do with this?
I had a little time today. I installed my FU lights in the rear bumper. They are the Hella black series. I also took a shot of these cool little tag lights I found.
Tire Wheel Vehicle Automotive tire Hood
Back to the console to get it buttoned up. Here is main section. I put the USBs in to connect to trans and engine controllers. I installed the passenger seat and it's seatbelt connector on the console side. Basically I put it in so I had a place to sit comfortably while squaring away all the stuff crammed into the console. Getting closer to taking her for a spin.
Camera lens Camera accessory Audio equipment Cameras & optics Gadget
Seatbelts,seats and console installed. I was hoping to paint the rest of the dash pieces but it's been too rainy. I need lower humidity.
Vehicle Car Hood Motor vehicle Steering part
Vehicle Motor vehicle Hood Automotive tire Automotive exterior
Reactions: 2
Had to post this shot.
Hood Blue Motor vehicle Automotive tire Vehicle
Reactions: 3
Looks great SHO!
Reactions: 1
2
Ever seen rocksliders in a SHO?
Motor vehicle Hood Automotive lighting Automotive design Vehicle
Hood Grey Automotive design Bag Automotive exterior
Reactions: 2
Those are pretty nice looking
i like those! did you have them fabbed from a drawing or do them yourself or how ? they look good and beefy enough to protect
I bought them from this post.
They are super beefy.
9
So you know I had to rush home and clamp one on. I'm like a little kid with this thing. These are very nicely done. They definitely had a jig. The center support lines up with bolts on the xfer case skid plate. There is a hole for the in the rear support for the factory assembly pins(fangs I should have removed). Very nicely done. Another thing I was concerned about was my body being square on the frame when I reassembled everything. The sliders show that it is. I guess it's time to set down my purse and drill a bunch of holes.
Tire Wheel Automotive tire Motor vehicle Vehicle
Tire Wheel Motor vehicle Automotive tire Hood
Vehicle Hood Automotive lighting Motor vehicle Automotive tire
Automotive tire Tire Wheel Motor vehicle Automotive lighting
Tire Wheel Light Automotive tire Motor vehicle
Automotive tire Motor vehicle Vehicle Tire Car
Bumper Motor vehicle Automotive tire Gas Automotive exterior
Hood Yellow Motor vehicle Bumper Automotive exterior
Reactions: 3
8
Driver's side bolted up. Here is pics from every angle. I had to remove the bracket for the brake cables from the frame. I could have trimed it but I want something cleaner looking.I I'm going to need to find a different(adjustable) intermediate brake cable I think. I may just go with the Lokar set up. Jury is still out. The disk brakes I used require the ebrake be actuated occasionally as they adjust the brakes. Overall I am very please with my purchase.
Motor vehicle Automotive tire Tire Hood Road surface
Tire Wheel Automotive tire Hood Motor vehicle
Tire Wheel Vehicle Car Automotive tire
Motor vehicle Automotive tire Hood Automotive exterior Bumper
Blue Wood Automotive tire Motor vehicle Gas
Automotive lighting Motor vehicle Hood Automotive tire Automotive design
Tire Motor vehicle Tread Automotive tire Hood
Reactions: 1
Why is the step towards the rear? Seems the step would be towards the front to help you get in no ? Or is that to reach into the back?
