It's a Kicker. It can be used as a step but the purpose is to kick the ass end away from trees and rocks there by protecting the rear quarter panel. I'm going to add a removable step before I paint.
It's a Kicker. It can be used as a step but the purpose is to kick the ass end away from trees and rocks there by protecting the rear quarter panel. I'm going to add a removable step before I paint.Why is the step towards the rear? Seems the step would be towards the front to help you get in no ? Or is that to reach into the back?
This makes me feel better. I think I got the last set. I was super nervous about it but these look absolutely fantastic. I'm having mine powder coated. I'm trying to figure out how to make them not so slippery when I powder coat them. I'm think some 3m walk tape.Driver's side bolted up. Here is pics from every angle. I had to remove the bracket for the brake cables from the frame. I could have trimed it but I want something cleaner looking.I I'm going to need to find a different(adjustable) intermediate brake cable I think. I may just go with the Lokar set up. Jury is still out. The disk brakes I used require the ebrake be actuated occasionally as they adjust the brakes. Overall I am very please with my purchase.
View attachment 212781 View attachment 212782 View attachment 212783 View attachment 212784 View attachment 212788 View attachment 212785 View attachment 212786 View attachment 212787
I'm POR15ing mine so they are easier to touch up. I was thinking about sprinkling some sand in the foot use area. I was also thinking about maybe putting a little Raptor Liner patch there. Maybe a rubber something 🤔This makes me feel better. I think I got the last set. I was super nervous about it but these look absolutely fantastic. I'm having mine powder coated. I'm trying to figure out how to make them not so slippery when I powder coat them. I'm think some 3m walk tape.
That’s a good idea. I have some Eastwood chassis paint that would be better to use and wayyyyyy cheaper. It’ll be easier to touch up. I figured the raptor liner would be slick!?I'm POR15ing mine so they are easier to touch up. I was thinking about sprinkling some sand in the foot use area. I was also thinking about maybe putting a little Raptor Liner patch there. Maybe a rubber something 🤔
Raptor would be harder to touch up bit not slick if sprayed at a higher pressure. It makes it like sandpaper. I have degreased and metal etched mine. All the 32 holes are drilled. My daughter has conference championship tomorrow thru Saturday so I won't get them painted until next week. Regionals, Super Regionals and World Series hopefully will follow. So may be the end of June I will have them mounted.That’s a good idea. I have some Eastwood chassis paint that would be better to use and wayyyyyy cheaper. It’ll be easier to touch up. I figured the raptor liner would be slick!?
@BigBlue 94 any experience or input on how to paint these durable with a texture that will be nonslip? I think this is your area of expertise lol.Raptor would be harder to touch up bit not slick if sprayed at a higher pressure. It makes it like sandpaper. I have degreased and metal etched mine. All the 32 holes are drilled. My daughter has conference championship tomorrow thru Saturday so I won't get them painted until next week. Regionals, Super Regionals and World Series hopefully will follow. So may be the end of June I will have them mounted.
Powder is the worst for bumpers and sliders imho. Sliders especially because they will be taking a lot of abuse. PC loves to peel once chipped or scratched through the entire mil thickness of the coating.@BigBlue 94 any experience or input on how to paint these durable with a texture that will be nonslip? I think this is your area of expertise lol.
They look good. Why por15? If it gets knicked it’s pretty known for flaking.Degreased, metal etched, 2 coats of POR15 and 3 coats of POR15 topcoat. I'll let them dry good and install as soon as I get time. Salisbury won their Regional and have supers Friday and Saturday. If or should I say when they win we leave for the world series in Texas on Wednesday. Hard to squeeze in time right now.
View attachment 213727 View attachment 213728
It doesn't flake unless applied wrong. That stuff is tough. My frame, suspension, under and inner body are all coated in it.They look good. Why por15? If it gets knicked it’s pretty known for flaking.
Gotcha. Well they look good. I’m painting mine with bed liner. I got them to the shop last week. I haven’t seen them in person but the pics look great.It doesn't flake unless applied wrong. That stuff is tough. My frame, suspension, under and inner body are all coated in it.
Thanks. I considered doing them in Raptor. Having to mix a small batch of fairly expensive Raptor, whose shelf life is a year, according to UPOL, seemed a pain when it comes to touch ups, not to mention the 5 day cant get wet deal. Man that's a sentence, probably grammatically incorrect. I'm going to try to get them on tonight.Gotcha. Well they look good. I’m painting mine with bed liner. I got them to the shop last week. I haven’t seen them in person but the pics look great.
No it's not, been on my EXO cage for close to 20 years. It only flakes if you paint POR over the old POR with zero prepThey look good. Why por15? If it gets knicked it’s pretty known for flaking.
I painted a bare piece of sheet metal that had a light coat of rust with no prep. It was the patch for the hole I put in the cowl to seam seal the area around the ECU. It flaked as you described. You have to metal etch or use an etching primer. I have determined the chemical metal etch is better because of the protective zinc coating it leaves behind. Here is what the bed looked like after sandblasting and then metal prep.It doesn't flake unless applied wrong. That stuff is tough. My frame, suspension, under and inner body are all coated in it.
I’m actually having the shop do them. He is already doing a lot for me. I don’t think anymore could be packed in by 6/5. They’ll do it when they do my motor and transmission swap.@BigBlue 94 I hope you have strong shoulders and sharp drill bits. 38 1/2" holes to install sliders. I couldn't find my cheater handIe for my Dwalt. I started with 1/8" pilot and used 7 increasingly larger bits to get to the 1/2". My wrists thanked me. Am assuming you are installing these on @Burntoutaccountant 's Steed.
Yikes. That sounds terrible. I would have welded them puppies on.@BigBlue 94 I hope you have strong shoulders and sharp drill bits. 38 1/2" holes to install sliders. I couldn't find my cheater handIe for my Dwalt. I started with 1/8" pilot and used 7 increasingly larger bits to get to the 1/2". My wrists thanked me. Am assuming you are installing these on @Burntoutaccountant 's Steed.
Thats the best use for an extension ladder ive seen lol!Degreased, metal etched, 2 coats of POR15 and 3 coats of POR15 topcoat. I'll let them dry good and install as soon as I get time. Salisbury won their Regional and have supers Friday and Saturday. If or should I say when they win we leave for the world series in Texas on Wednesday. Hard to squeeze in time right now.
