Yo borgescaio87,
Welcome to our DIY BIG Bronco community
94-96 Cab Step, according to Ford in
REMOVAL AND INSTALLATION
Step, Cab, F-150, F-250, F-350, Bronco
Removal
Installation
In ATTACHED diagram; Cab Step Parts Break-Out Diagram w/nomenclature in 94-96 Bronco & F Series; "...The factory bracket is made of thin-walled tubing, so it collects water & mud, and rusts out. It's also very susceptible to damage. The factory bracket #5 without anything attached weighs ~5lbs; mine weighs 11-18lbs, depending on the thickness of material I use..." by banned member Steve83
Find out if speed control, if equipped, recall work is completed.
If you still have concerns about Recalls, please contact the Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 711.
... have VIN ready.
See this guide by member jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
For any Bronco questions or to chat about desired modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (50 posts required to participate due to scammers who preyed on our members ).
See 93 Body/Chassis and Drive Train Manuals @ 1993 Ford Truck Service Manuals - Google Drive
In pop-up, Click "Drive"
Here is the 1993 Bronco Dealer Brochure in Google Drive @ 93Bronco.pdf
1993 Bronco Dealer Training Video via member silver70 @
1993 Bronco, Venezuela Commercial @
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via member BroncMom!
See my mostly recovered site by member schwim @ Ford Bronco And F-150 Links - FORD BRONCO
It contains boo-koo component repairs, installation & parts sources.
See How to add your 93s Signature @ Bronco Forum - Full Size Ford Bronco Forum by BigBlue 94
Our Forum FAQs includes for example; How To Upload Images To Posts, How to Use Search,
How To Edit A Post, How To Delete a Post, How To Find Your Content and more tips!
➡ Baba Looey's Favorite FSB Links (lots and lots of tech links)including, "how do I get the tailgate glass to...", etc
Try to find time to participate and vote in our next Full-Size of the Month Contest & later in the year, Full-Size of the Year Contest @ Voting
You will get ideas by those competing.
Prizes are awarded to Winner; a full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted; and a years worth of premium FSB membership!
Al
Section 01-08: Trim, Exterior | 1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual |
Removal
- Remove the cab step mat from the step.
- Remove step-to-body frame bolts.
- Remove the cab step bracket-to-frame bolts.
- Remove the step and bracket assembly from the vehicle. The step can now be removed from the bracket by removing the stud nuts.
- If the cab step front fender brackets are damaged, they can be removed for replacement by removing the bracket bolts. Refer to the following illustration;
Installation
- Follow removal procedures in reverse order.
- Tighten all step bracket-to-frame bolts to 20-28 Nm (15-21 lb-ft) and step-to-frame bolts to 8-11 Nm (71-97 lb-in). Tighten front fender bracket bolts to 8-11 Nm (71-97 lb-in).
Cab Step Installation
Item Part Number Description 1 N605905-S55 Bolt 2 N605891-S55 Bolt 3 16A470 Cab Step 4 N620481-S55 Nut 5 — Cab Step Bracket (Part of 16A506) 6 N605909-S55 Bolt 7 16C078 Front Fender Mounting Rear Bracket A — Tighten to 20-28 Nm
(15-21 Lb-Ft)B — Tighten to 8-11 Nm
(71-97 Lb-In)
94-96 F-series & Bronco Cab Steps (Running Boards F1TZ16450AK) (Original kit: F3TZ-16450-L) ERROR: The L bracket #7 in the Bronco inset (for the quarter panel) is NOT the same PN as the front one (also marked #7). The (Bronco only) rear bracket (F4TZ16488A) has 2 anti-spin tabs; the front (F2T316C078AB) has only 1. The same bracket is used (in each case) for Left & Right. ![]() NOT CALLED OUT: foam self-adhesive weatherstrip (F2TZ16536B) on top edge of step (#3) Installation & Alignment: 1) Install the step assembly (#3) onto the bracket (#5) using 2 nuts (#4, 13mm hex) 2) Install bracket (#7, x2 for Bronco) loosely 3) Position the step & bracket below the body; install 4 rocker bolts (#1, 10mm hex) loosely) 4) Install 2 inboard bolts (#6, 10mm hex) loosely 5) Raise step so its top edge contacts the bottom lip of the rocker/fender/quarter; align the front curve of the step with the front wheel arch; tighten 4 rocker bolts 6) Push the step inboard so its outboard edge aligns with the lowest body line; tighten 2 inboard bolts 7) Install 2 tab bolts (#2, 8mm hex) and bracket screw (#8, 5.5mm hex, x2 for Bronco) and tighten The factory bracket is made of thin-walled tubing, so it collects water & mud, and rusts out. It's also very susceptible to damage. The factory bracket #5 without anything attached weighs ~5lbs; I'm not sure how much the $500 reproduction version weighs (but it won't work if your steps' long studs are rusted off); mine weighs 13.5 lbs. See also: ![]() ![]() ![]() by Steve ___ TSB 95-08-06 RUNNING BOARDS - INCORRECTLY INSTALLED -NOISE VIBRATION HARSHNESS CONCERNS Publication Date: APRIL 24, 1995 (This TSB is being republished in its entirety to include vehicles through the 1995 model year.) LIGHT TRUCK: 1987-90 BRONCO II 1987-95 BRONCO, ECONOLINE, F-150-350 SERIES, RANGER 1988-95 F SUPER DUTY 1991-95 EXPLORER ISSUE: Running boards which are incorrectly installed may result in noise/vibration complaints. ACTION: Install running boards to either the body OR the frame; NEVER to both unless the mounting system uses isolated mounts. A manufacturer's instruction to attach running boards to both body and frame should be immediately questioned because such action provides a direct path from chassis to body for road vibration and noise. OTHER APPLICABLE ARTICLES: NONE SUPERSEDES: 91-04-11 WARRANTY STATUS: INFORMATION ONLY OASIS CODES: 108000, 702000, 703000" By Ford via banned member Steve83 See more @ http://web.archive.org/web/20130914203134/http://www.supermotors.net/registry/2742/ Cab Step Bracket Refurbishment in a 96 Source: by member bossind (boss, Steve) |
... have VIN ready.
Al
