1 - 4 of 4 Posts
The story goes:
One day it was working, didn't drive it the next day, and the following day...just get a turnover but not starting...
Ive checked the connection of fuses, plugs, and has plenty of gas. What else can I check before taking it to someone? And not being very mechanical, is this "do-able" for a new Bronco owner....I'm affraid its a fuel pump issue...I hope not!!!
Thanks for any advice!!!
BigBlue93 (Jim)
everyone else says search... check for spark, coil and plugs. do you hear the fuel pump when you turn it on? No fuel, no start. If you search for other posts they have a lot of info. if you cant check this stuff you need to take it to someone. narrow down the problem.
Things to check:
Negative Battery Cable - Just b/c it spinning doesn't mean all grounds are good
Spark at coil
Spark at dist. cap
Fuel rail getting fuel (tire spicket looking thing on fuel rail)
1 - 4 of 4 Posts
