So - my motor crapped out on me a couple of weeks ago (not really crapped out - just won't make oil pressure...175,000 miles - plus it's pissing out the rear main like the Exxon Valdez).
I can get a motor from a 94/95/96 for pretty cheap with only 95k on it.
What would I need to swap off my motor to this one to make it work ?
they're both 351's.
I did try searching - but "motor swap" "351 swap" etc. don't narrow it down enough.
Thanks ! Dan
I would definitely swap the intakes etc.
I just - just purchased a set of Hedman's from Summit - hopefully they'll bolt up. I have no air pump and blocked the holes in the backs of my heads from the crossover pipe.
I may just get the motor - then do a rebuild on it over the fall and winter. But then again..it is "only" 95,000 miles.
Dan
