yo,
I keep losing Comcast cable and it is too slow to load your pics..
so
Housing Removal & Installation in a 87-88 & 89-96 (under license from Delmar Publishers, comb of Chilton/Nichols/Delmar & Haynes);
Evaporator Core Housing REMOVAL & INSTALLATION
I would skip da parts that say to discharge da system since Steve knows more than the NEW tech "writers" @ Chilton/etc...
1.Discharge the refrigerant system using a certified recycling/recovery station
2.Disconnect the vacuum supply hose at the dash panel. Position the check valve (this is da Vacuum Check Valve shown in Steve's Diagram, below - (Vacuum Diagram in 92-96)[/) away from the case. See the same diagram below by Steve (Vacuum Diagram in 92-96)
3.Using a quick-disconnect coupling tool, disconnect the liquid line at the evaporator core. Cap all openings at once!
4.Using a back-up wrench, disconnect the suction line at the accumulator. Cap all openings at once!
5.Drain the cooling system. Miesk5 Note; drain a little until hoses are relatively frr of coolant; may as well replace both anyway
6.Disconnect the heater hoses at the core. I split em there with a sharp knife/razor so I don't frig up da core tubing esp since I replace those hoses anyway.
7.Working in the passenger's compartment, remove the 2 screws or nuts attaching the bottom of the case to the dash panel. One screw also secures the lower edge of the plenum.
8.Disconnect the vacuum and wiring harnesses located at the right end of the plenum.
9.Remove the 2 screws attaching the right side of the recirc duct to the dash panel.
10.Remove the 2 nuts attaching the evaporator case and recirc duct to the dash panel.
11.Pull the evaporator case and recirc duct forward and out of the truck
SEE Steve's pics (in my post above) of the cover for an idea of the screw holes..etc.
To install:
12.Position the case assembly in the truck and install the screws and nuts attaching it to the dash panel.
13.Connect the vacuum and wiring harnesses.
14.Using new O-rings coated with clean refrigerant oil, connect the refrigerant lines. Tighten the suction line, using a back-up wrench, to 28-33 ft. lbs. (38-45 Nm).
15.Connect the heater hoses.
16.Fill the cooling system.
17.Evacuate, charge and leak test the refrigerant system (refer to ).
A detailed Diagram;
10 19850 Evaporator Assembly
Item Part Number Description
1 56956-S2 Screw and Washer Assembly
2 N621906-S2 Nut
3 45261-S2 J-Nut
4 18471 Chamber Assembly, Plenum
5 56950-S2 Screw, Washer Head
6 — Vacuum Hose (Part of Vacuum Harness)
7 18C433 Duct Assembly
8 01610 Dash Panel
9 N801696-S2 Nut (As Required)
10 19850 Evaporator Assembly (All)
11 12A581 Wiring Assembly (All Engines Except 7.3L Diesel Engine Without E4OD Automatic Transmission)
12 18A586 Wiring Assembly
13 18D306 Cable Assembly (Temperature) Blue End
14 — Vacuum Tubes (Part of 18A586)
15 — Install Locator in Hole in Bracket
16 N803946-S Rivet, Blind Truss Head
17 N621906-S2 Nut
18 N803912-S2 Stud
19 14401 Wiring Assembly
20 — To 19980 Control
21 M4G195 Sealer
22 9F479 Manifold Absolute Pressure Sensor and Bracket Assembly
23 — To Right Anti-Lock Brake System Sensor Connector (Bronco Only)
24 19E746 Clip, A/C Tube Lock Coupling
25 — Locator (Part of 14401)
A — Tighten to 2-3 Nm (18-27 Lb-In)
B — Tighten to 2-4 Nm (18-35 Lb-In)
C — Part Number Location on Cable
D — Install in Hole Provided
Outside A/C Box Parts Break-Out Diagram w/Out Nomenclature in 92-96
Source: by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/registry/media/883867
