My Ford schematics show no resistor between the coil (-) terminal and the tachometer.
I think I ran into a similar conundrum. IIRC, they "doubled-up" that tan/yellow wire, so that one lead could go back to the PCM, and the other to the remote-mount ignition control module. Where that splice is for the tach, I don't remember exactly, but it exists. In the schematic for the later setup (CCD), there's a single coil (-) line off the ignition module, and it's split between the coil and the tachometer. Wish I took more pictures when I did mine. :cry
EDIT: Hang on, I found some!!! :chili: I'll post as soon as I resize 'em.
EDIT 2: The first is a "before" pic, the second, "after". Note that I only modified the lines going to the 22kΩ 0.5W resistor, not the resistor and diode for the lines in the lower part of the pic (those are for the a/c clutch).
