1 - 10 of 10 Posts
this isnt on my bronco but close
I searched but never found anything helpful
I was driving home in 4-lo (long story, shift fork broke, lost 1-2 gear)
and my front end popped when i went up into my driveway, losing my 4x4, and replaced with a clunking. Checked it out, i broke my slip shaft and bent my u-joint on the D-44 frontend. the passenger side and the black grommet is ok, but yea.
How much would the parts cost and is this something i could easily change with a buddy of mine?
Convicted Drunk Dialer
You mean the driveshaft or axle shaft? I dont have a TTB, but I dont remember there being a slip joint last time I was in one. If its the driveshaft, piece of cake. If its an axle shaft, you gotta tear apart at very least a hub.
axle shaft, sir.and i kind of figured but i didnt know if it would somehow magically fit without removing anything since i gotta replace the ujoint 2
It's BTW Not AKA!
What you described breaking is a classic weak point in the TTB. Consider swapping in a D50 slip shaft. Or, you could just get a new stock slipshaft and replace the u-joint.
My advice, while you have it that far torn down, go ahead and replace anything that you can.
Check this thread for teardown instructions and possible parts to replace: http://www.fullsizebronco.com/forum/showthread.php?t=113559
And this thread for the D50 slipshaft upgrade: http://www.fullsizebronco.com/forum/showthread.php?t=13107&highlight=d50+slip+shaft
Hope that helped.
hmm. actually is there like a quick cheap fix or anything like that? im looking to get rid of it so i have another bronco :cool: but yea. i wonder if i welded the slip shaft back together?
haha thanks
It's BTW Not AKA!
haha thanks
No. You disassemble it, and fix it. What are you going to weld if you broke the shaft and bent the u joint? Do you have any pics of the damage?
here you go
It's BTW Not AKA!
No easy fix for that. gotta replace the shaft.
Alright
Thanks for the information and such guys,appreciate it!
Or just not sell it and do a sas.
1 - 10 of 10 Posts
