94 vs 95 dash wiring
  • Pull the dash and replace with 94 harness
    Votes: 0 0.0%
  • Keep the 95 harness and re-wire
    Votes: 0 0.0%
I have a 94 XLT 351W Ford bronco. I replaced my dash/dash wiring harness with a 95 EB 351W. She doesn't want to turn on now. The engine is rotating but sounds like she is not getting fuel? I checked the inertia switch but still no luck. Am i suppose to transfer over some computers? Was i dumb in thinking it was a direct replacement? I still have the 94 harness that I can put back in. FB LINK HAS VIDEO Kevin Villalba
LI
174545
174546
174547
174548
Kevin Villalba
Charlie don't surf..
'92 Ford Bronco XLT
pretty sure those harnesses should be identical..I see what looks like the chime module and transfer case control module..don't know what the others are..do all the plugs have a home? What about remote keyless entry or an aftermarket alarm...if you have that on your current harness but not on the new one maybe that's the problem..
Why did you swap the harness to begin with?
Reactions: GetBent4x4
96 EB
Maybe something else messed up coincidentally while you replaced the wiring. Do you hear your fuel pump engaging? Almost sounds like that too.
Man of endless projects
heres 95 bronco. did not check for any actual differences. both are from same EVTM but different pics so there may be some. sometimes male and femal side oc connector will have different circuit number and colors so i posted both for C202
174567
174568
174569
