Got a 95 and the ac selector doesn't seem to work. The ac works but when I switch from ac to defrost, it continues to blow through the front vents and not the defrost. I am sure the selector switch is bad but I can't get anyone over at LMC to confirm if the part they have is the correct part I need. Any help would be appreciated.
UPDATE, I FOUND THE PROBLEM. The vacuum module under the dash was not connected the plastic control arm for the vent control (I believe that is the technical explanation). We are back in business.
