1 - 3 of 3 Posts
Trying to install a Viper 3105 in my 95 Bronco XLT, which has automatic door locks and windows. I can not get the door lock remotes to work. Everything with the alarm works except the door locks (which is why I brought it). I believe it once had a keyless module installed but the module is no longer there. I can trigger the lock/unlock by tripping the pink/yellow and pink/LG wires in the passenger kick panel to ground. After reading many of the posts here, I purchased a 451M relay. I installed it as a Type C, but it didn't work. I called Viper and tech said it was Type B, and install Green/Black to Lock, Blue/Black to Unlock, and Purple/Black to Ground. Still not working... I have pulled multiple wiring diagrams but still a FAIL. Help!!!
Steve
95 Bronco XLT 5.8
1996 bronco, 351w, E4od
Sorry no one has replied. So im going to say if you could post some pictures and wiring diagrams maybe that would be helpful.
Yo SteveG123,
In event you need more wiring diagrams;
175266
Window/Door Lock Control Switch (Master/Left) (With Remote Keyless Entry)
175268
175270
175269
1 - 3 of 3 Posts
