Alright guys, I need some help from the experts! So as the title says I have a 95 ford bronco that has or had (I plugged the abs port) broken brake line. Now I do have a brand new rubber line that connects to the caliper I just need the hard line that goes to the abs module or whatever its called and it has a special fitting that I cant find anywhere.
fitting thread pitch for abs pump connection ?
brake line diameter ?
You can take the fitting from the old line and use it again. Just cut the brake line before the flare. Or you can do it in 2 steps, with an adapter bushing from the parts store. I dont remember what size they are but maybe 3/8 to 1/4 and that fits premade brake lines for the fords.
Sorry I may be confused here but the ABS line no thread pitch, it's a plug and play wire..
https://www.amazon.com/SKP-SK970020-Replacement-Wheel-Sensor/dp/B07GSK2FJK/ref=sr_1_fkmr0_1?keywords=skip+sk970020&qid=1568323737&s=gateway&sr=8-1-fkmr0
that's a wheel https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/507384-95-bronco-front-passenger-brake-line-repair-abs-fitting.html#post7244696 total different then a brake line? those are just a electrical component that sends a signal to the ecu. no fluid involved. so what exact part are you needing then? the other side of the plug?
I get that it's the speed sensor, but RLVBronco said he needs the ABS Line, he has a caliper line so I am confused as to what he really needs. A pic would be helpful..
