like i said i have a 95 bronco. a few days ago i was working on the dash and after putting it together again my bronco wouldnt turn over. ill turn the key and nothing happens. but when i use my remote start it will start and i can drive it but there is no speedo or odometer and the trans shifts eradictly. my eec wont even come on. any help is appriciated :chili:
· Service before Self
Did you take the steering column apart? Check the ignition switch. (Top of the Steering Column). Check for 1) mechanical connection with the push rod in the steering column AND 2) That you didn't dislodge the electrical connector that plugs into it...
